On a 73 1300, is the hazard and flaser relay the one. If it is, does anyone know the bosch part number for this relay.
Thanks Trevor
yep its the same on all VWS ring Vintage for the correct part and service
did you check the wiring under the coloum
Whats the problem with yr system
clinker42 ·
There isnt a problem except that there is no wiring loom, its a bare sheel build up. Ran the new loom yesterday, wired up the rear loom as in engine and tail lights, brake lights and ign etc. Wired up a front loom and did the indicators headlights etc, now just connecting it all at the dash
Making the front loom, rear loom and main loom was pretty easy, wiring up the flashers and head lights is a real pain. They are all linked together in with the Indicator switch, hazard switch, hazard/ Ind relay and the head light relay. Wires going from one to the other and crossing over etc etc etc.
Only real pain is when you find a decent wiring diagram they list color codes bt dont have pin outs, plus color codes dont always correspond.
