how to wheel stud question, help needed urgently PLEASE!
https://forums.aussieveedubbers.com/threads/8231/how-to-wheel-stud-question-help-needed-urgently-please
type3kid ·
hey all, i'm trying to put my mags ontop my t3 and i'm having difficulty. i was told to use combi studs and i'm not sure what i'm actually meant to do with them, can someone fill me ni please
type3kid ·
c'mon someone has to know!! i'm hoping to hacve them on tonight..
Tell us more about your problem
type3kid ·
i've got kombi nuts and bolts and a t3 rear drum, what do i do to get them fitted properly
amazer ·
Pull the hubs off the car.
Measure the size of the kombi stud, the splined bit. Drill the threads out of the hubs with a slightly smaller drill. A reamer would be nice here. then whack the studs in with hammer or a press if you're lucky enough to have one.. You might have to do a little filing of the hole.
type3kid ·
amazer ·
the stud. put the stud through the hole. But dont make the hole too big else the stud will turn when you try and put the wheel on.
type3kid ·
please excuse my lack of tech knowledge but i'm assuming the spline is on wider circle part on the end of the stud...
amazer ·
yep. thats it.
type3kid ·
and that's secure enough to hold the wheel on, you sure?
amazer ·
Thats the only thing that holds a kombi wheel on.
type3kid ·
cool, thanks mate
amazer ·
If you're not sure, maybe you should wait till Valla and I will pull a wheel off and show you.
type3kid ·
i've got a rooted rear axle at hoime with the drum on it so if i try it on that and it doesn't go to good i'll leave it to safer hands
Tazz ·
You can do it mate!
:thumb:thumb
Good idea with the spare!
But remember when you remove the stud again..
put the nut on it so you dont Bur the thread!
