Indicator/High Beam and Wiper Switch Wiring
https://forums.aussieveedubbers.com/threads/82320/indicatorhigh-beam-and-wiper-switch-wiring
clinker42 ·
Hi Guys
Does anyone have a link or know where ic an find some stuff on the wiring for the wiper Switch and Indicators/High Beam for a 1973 1300 Standard Beetle.
I have searched every where and I can find wiring diagrams but they are in sufficient to wire the car. They all show wires and colours and where they go to but dont show the pin outs. Its no good knowing that a black green wire goes to a hazard switch unless they tell you which pin/terminal it should connect to.
All I can find is dieagrams that show say 6 wires go to a switch.
I dont mind buying the diagrams if anyone knows where I could get one.
Thanks Trevor
annosL ·
I have a "bug-me" video on beetle wiring which Rick what's-his-name shows the pinouts on later bugs, I will have a gander for you
annosL ·
No good with video, doesn't show the pin wires, but the last time I had my column mounted switch lever gadget apart inside it is short lengths of the coded wires from the actual switch to the pins which will give you which is what, maybe try that?
silver ·
Just google what you want you will find Hundreds!
Heres some links
http://www.thesamba.com/vw/archives/info/wiringt1.php
http://www.thesamba.com/vw/archives/info/wiring/bug_std_super_72.jpg
clinker42 ·
Checked all the Samba ones for a 73 and none show pin outs. But that 1972 Bug/Super shows pinouts. I will wire it up as per that.
Thanks Guys and Silver
