i have just realised i have 44'idf's on 48mm manifolds,. so will this effect flow and HP. im guessing its not good for performance but some tech info on this would be great...
thanks...
cnfabo ·
hhmmm, NO ONE??
I have been told they will fit
It is a one size manifold
99% of the IDF manifolds that you buy today are suited for the 48 size.........It will make bugger all difference.
What about the bottom end??
Mine are "small bore" manifolds and suit my stock heads
if yours are "48" manifolds are they some H-U-G-E mother manifold port
That may effect stuff if you have stock inlets on your heads
Most manifolds are this way. It's the way it is and although I like to see back to back tests, I don't think you have a lot of options. It's not a big deal but I agree it doesn't look the best for low speed response.
Just means you should build a bigger motor and run 48's. 😀
cnfabo ·
they are match ported to the heads and are not stock ports. i thought i had a miss match and that 44 idf manifolds would come to 44mm at top of manifold. but cool, if thats the case then there staying on... thanks boys....
