Cams Engle TCS-10
https://forums.aussieveedubbers.com/threads/82381/cams-engle-tcs-10
turboboy ·
Howdy
I have my engine stripped ready for rebuild. It's a 78.4 X 90.5
d port heads.The plans is for turbo to be fitted. Toss up between Kawell kit or local , yet to decide, Bloody freight and import duty!! I should buy local . Around 250 hp is the mark with option of turning up the HP.
The question is what cam.
Is is going into a street buggy.
Has anyone used the Engle TCS-10 or TCS-20 TCS- 30 etc etc. TCS- 10 would be my choice not shore to go any bigger?
When you look in to it there are a lot of turbo cams but they are one of the few with a bigger lobe center 112*.
Kawell dose not have his cams made any more but recon's a FK-8 would work well, but you need rocker 1.4 or bigger , mine are smaller.
Any help greatly appreciated😉
vwo60 ·
hi, i won't comment about the cam but as for the freight you do not pay duty or GST up to $1000 US, i import all my gear from the states and have yet to pay any duty, talk to the supplier and in most cases the invoice can be set to round the $1000 US, you can also break down the shipment to a couple of packages, i only use USPS and it normally arrives in about 6 to 8 days,if you UPS it will be very expensive, i can land a set of 44IDF's for under $1000 AUS total cost jetted and choked to my specs.
