Thanks Gazman, unfortunately none of those ecu`s match mine.
Will keep searching.
Cheers, Keith
jzk25 ·
Post a pic of the ecu connectors please.
Keith Haeusler ·
Hi jzk25,
Heres a pic of the ecu connectors.
Regards, Keith
jzk25 ·
Cool, how about a pic of the engine too.
I promise this is leading somewhere, not just asking for random pics. 🙂
Keith Haeusler ·
Here you go, pic`s of engine as requested.
Thanks mate.
Keith
jzk25 ·
Ok. it's an avcs EJ25 from a Gen3 legacy, I'm thinking it's probably more a 99-00 model than an 02. Have a look under the oil cap for a date stamp to give an approximation.
Is the ecu Jecs or Denso made?
That's a fairly rare engine, hence the difficulty in finding a pinout. I could work it out without a pinout if necessary but that doesn't help you.
Keith Haeusler ·
Thanks mate,
It is stamped 2nd month 02 under the oil cap. The ecu is jecs made. You seem clued up on this stuff, am i pushing s#*t uphill with a pointy stick with this thing. I am trying to fit it in a T3 auto.
Almost all the harness is terminated at plugs for the engine, i don`t know fuel pump wire, vss? etc. Alot of wires ran into a large white multi pin plug on rhs. There was no gauge cluster so not sure if this was a plug for that?
Thanks alot for your help.
Cheers, Keith
jzk25 ·
Big multi pin plug on RHS with a thread in the centre is for the dash wiring.
It'll have acres of unnecessary wiring going to the ecu, especially being auto originally.
If you start stripping it, make sure you keep it all taped together, if it gets to a birds nest state it's practically throw away.
If you get desperate I can do it for you, it's my thing. 🙂
