'69 1500 Jerky under Throttle
https://forums.aussieveedubbers.com/threads/82494/69-1500-jerky-under-throttle
eplatypus ·
My 1500 Beetle is jerking under throttle. It idles fine and under engine braking, all is good too. When I accelerate though, it's jerking back repeatedly. It's more noticeable lower in the rev range but it's also there if I accelerate hard too. I'm going to try and take it down the mechanic tomorrow, but any ideas?
Thinker ·
my 1500 is doing that at the moment and lacking in power down low once up and running its fine.
your motor may being doing it for different reasons but a compression test will tell you.
i tested mine last weekend and i have lost 75% compression in no 3 so at low RPM it get the wobbles.
good luck
greedy53 ·
could be 1 of 2 things
1 the vacume on dizzy is shot
2 accelloor fuel pump is shot
3 check points
eplatypus ·
FINALLY get back here with an update. 'Twas the spark plugs needing replacing, completely fouled up. All changed and all good now.
Ta for the replies, much appreciated.
