Aussieveedubbers 路 Tech Talk
Dipstick sender
https://forums.aussieveedubbers.com/threads/8252/dipstick-sender
waltermitty 路
I have a dipstick sender (-BERG) and thought that I might give it a go. Its fairly obvious to me where i install it but where do you connect the wire too?
Thanks . MitCheLl馃槑
vw54 路
On the temp gauge there should be 2 terminals.
One goes to the sender unit and the other side goes to a positive on the fuse box that activates when the ignition is turned on.
The temp sender sends a resistance signal to the gauge that makes it moove when the oil temp increases.
Keith Haeusler 路
Mitchell,
The wire hooks to the oil pressure light wire. Use a piggy back from the o/p switch to attach both wires. Keith.
vwtestpilot 路
Check it out here...
http://www.geneberg.com/tempdipstickhtm.htm
Barry.
