Ignition Timing
https://forums.aussieveedubbers.com/threads/82559/ignition-timing
clinker42 ·
Hi Guys
What total timing do you guys run on your modified bugs. Its a 1660 with heads and mild cam. Hoping one of you have dynoed a similar setup and know what total timing your running.
Are VW's like most other carbed engines, 32 or 34 degrees total about right.
Thanks Trev
I wouldn't go over 32, maybe even 30. What sort of dizzy are you using?
clinker42 ·
Some old cheap thing from George with an Electronic kit in it.
clinker42 wrote:Hi Guys
Thanks Trev
using a 009 dizzy [mechanical only]
I have mine at 32 degrees...
stock single port 1600 engine... running standard unleaded..
runs great...
I have been told that 28 degrees should be the maximum
for a 009 mechanical dizzy....??
I used to run premium fuel....
goes just as good with normal unleaded...
