Nasty clutch noises
https://forums.aussieveedubbers.com/threads/82589/nasty-clutch-noises
btc-er ·
Last night my 61 Beetle started to make some disturbing noises every time I put my foot on the clutch. Its a nasty metallic grinding sort of noise. She still shifts fine and there's no change in clutch feel. The noise is only apparent when the clutch is in.
Can anyone suggest a likely cause? Bearing perhaps?
FWIW, I was told a month or so back that the front gear box mount had a split in it...
btc-er wrote:Last night my 61 Beetle started to make some disturbing noises every time I put my foot on the clutch. Its a nasty metallic grinding sort of noise. She still shifts fine and there's no change in clutch feel. The noise is only apparent when the clutch is in.
the original clutch bearing in early beetles, was a carbon type which do wear out... then metal to metal...
split front gearbox mount doesn't usually affect anything...
otherwise its a thrust bearing gone dry and wearing out...
engine needs to come out... to fix either problem...
jsheppard64 ·
replace those rubber mounts while the engine is out aswell
btc-er ·
Thanks for the response. I took her for a short drive yesterday and there were no dodgy noises. Hmmm.... perhaps it needs to be fully up to operating temp? I guess I'll see what happens over the next few days, but I am mentally preparing myself to spend some quality time in my garage.
