So im still building and learning which is good. But the other night i got to the 1600 dual oil relief bit and i couldnt find the springs etc to go with them so i went out and grabbed one of those EMPI (I know but no one else seems to make them) http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-5326
Which was all good, but i was told that you dont want to put one of those pistons with the groove into a dual relief case.
But first issue was that the long spring with the new piston on it seemed a tad too long:
And tonight i found the original springs and pistons and this is what i saw...
Should i just cleanup & reuse the old ones?
Should i just use the nice shiny new pistons and old springs? Or are the springs fine and shrink from the pressure over time?
Also if it is ok to use the piston with the groove in it does it go onto the big spring or the little spring?
And one final question do the gasket kits come with the metal gaskets for the screws you secure these springs and pistons in with, because i have bought two lots and neither appear to come with the gaskets, can i just use the old metal gasket with a little bit of permatex on them?
As per normal thanks everyone for all your help.
eraser ·
