Kunifer solid brake pipe
https://forums.aussieveedubbers.com/threads/82602/kunifer-solid-brake-pipe
psimitar ·
Hiya all,
I'm wondering if anyone can tell me if kunifer, Copper/nickel, solid brake line is legal to use in QLD.
Would really prefer using this instead of crudey old steel. Much easier to work with and don't rust.
Mike
Sides ·
Technically, no - it doesn't meet ADR
Copper is OK tho for the SAE (British) standard tho... so apparently if you can prove your line meets that standard, then they have to accept it.
Details are on page 60 of the document at http://www.transport.qld.gov.au/resources/file/ebbf2d0f26cd09b/Pdf_veh_stds_ais_codeofpractice_section2b_feb2004.pdf
hellbugged ·
stainless steel wont rust
clinker42 ·
Hey
Can I ask where your using it why not just buy bundy tube. We buy bundy tube from the brake shop and I think it only costs like $25 a roll.
Sides ·
Oh also - what's the car for ??? Obviously driving on the road since you're asking about rego, but if you plan in racing it CAMS have a thing in there "brake lines must be steel 'bundy' tubing or equivalent".
Maybe not relevant for you, but hey - figure might as well mention it....
psimitar ·
Sides wrote:Technically, no - it doesn't meet ADR
Cool cheers for that shall have a look see.
Yea pure copper lines work harden from the cars vibrations and so can crack over time but the copper/nickel mix drastically reduces this. Also, the line should be at least tab mounted every half metre no matter the material to stop flexing as even steel will fracture but over a longer period than copper.
As for the CAMS regs again same deal so can't see why it can't be used. Even steel lines will rust in Oz but the kunifer won't 🙂
clinker42 wrote:Hey Can I ask where your using it why not just buy bundy tube. We buy bundy tube from the brake shop and I think it only costs like $25 a roll.
Using it for all the solid lines on my Beetle floorpan. What on earth is Bundy tube? Never heard of it. Whats it made of?
Hellbugged wrote:stainless steel wont rust
True but it's expensive and a right arse to work with for flaring and bending.
eraser ·
stainless will rust just like normal metal when exposed to another metal.
clinker42 ·
Bundy tube is the proper stuff for brake lines, you buy it in rolls from any brake shop. Exactly the same as you would see on all your Holdens, Falcons etc etc, probably even the same as the VW stuff.
Its your best bet, reasonably soft so you can bend it (within reason of course), last for 20 years.
psimitar ·
clinker42 wrote:Bundy tube is the proper stuff for brake lines, you buy it in rolls from any brake shop. Exactly the same as you would see on all your Holdens, Falcons etc etc, probably even the same as the VW stuff.
So must be steel then? Only brake shop I have in my area is ABS. Do they count? 😂
If it's easy to work with and flairs pretty easily then I'll go with it but I'm used to kunifer as it just so nice to work with 🙂
Steel bundt tube not as nice to work with, especially with the VW double flair.....working on cars isn't meant to be easy 🙂 where's the fun in that???
psimitar ·
matberry wrote:Steel bundt tube not as nice to work with, especially with the VW double flair.....working on cars isn't meant to be easy 🙂 where's the fun in that???
indeed a difficult car to work on is fun but steel lines are just crap. hate working with them cos even if the flare looks good it don't always seal properly cos it doesn't give like the kunifer. Just coming from someone who's used both if you ever used kunifer you'd never want to go back to steel 🙅
psimitar ·
Found this researching the SAE J1047 standard for solid brake lines, take note of the very last sentence
Properties of Copper-Nickel Brake Tubing
The copper-nickel alloy used for brake tubing typically contains 10% nickel, with iron and manganese additions of 1.4% and 0.8% respectively. The product conforms to ASTM B466 (American Society for Testing and Materials), which specifies dimensions, tensile strength and yield strength. Formability and internal cleanliness conform to specifications SAE J527, ASTM A254 and SMMT C5B (Society of Motor Manufacturers and Traders). Also, the alloy meets the requirements for pressure containment, fabrication and corrosion resistance for ISO 4038 (International Standards Organization) and SAE J1047.
Bingo, kunifer it is then 😎
