So what's the problem?
1st....2nd....3rd....4th all good but 3rd back to 2nd or 2nd back to 1st while moving is becoming almost imposible it's fitted with a Scat qhickshift.
please make this easy. 馃槀
vw54 路
first off check the selector plate under the shifter to see if u have one
and second to see if its fitted the right way around
if its there then loosen the 2 bolts and select second gear wriggle the knob and tighten the bolts centralising the shiffter as you go
donn 路
Ta, i'll give all that a go tomorrow night, any pics that might help?
BiX 路
How old is the gearbox? could it the synchro going?
donn 路
Just dosn't seem to line up properly, I feel the syncro is ok as there is no crunching when I do get it to go in.
