I have an engine kit here that is un-assembled and ready to go. Here is a list of components ;
Used Rimco prepped case $ 500
new welded 78mm vw crank $ 500
new Rimco super rods $ 200
new Mahle piston/barrel kit $ 450
new Engle 130 cam $ 137
new zinc coated push rod tubes $ 40
new Glyco dual thrust cam bearings $ 29
used vw rockers with swivel feet $ 60
new Daiken super disc $ 78
new Scat degree pulley $ 42
new Scat racing lifters $ 115
new Kennedy stage 2 plate $ 215
new Bugpac solid rocker kit $ 68
new Berg pressure relief cover $ 76
new Berg 8mm head stud kit $ 123
new Bugpac teflon buttons $ 28
new Clevite 77 rod bearings $ 37
new Mahle main bearings $ 80
new Shadek 30mm oil pump $ 55
new billet straight cut gears $ 168
new moly lightened flywheel $ 190
new MSD billet dizzy $ 425
new MSD heli-core wires $ 88
Reco street eliminator heads , ported , with matched IDF/Dellorto manifolds , new 42 x 37.5mm stainless valves , new dual springs , new moly retainers and new valve locks $ 1060
Used 44mm idf Webber carb kit $ 650
Over $ 5400 in value , all for $ 4800. Pick up in Wollongong 2526 , or delivery Australia wide , thanks ROD , 02-42729920 .
RodPenrose ·
