You need to remember that these cars have given good service for around 40 years so many parts are going to wear out...
plus, many parts which were supposed to be replaced every year at least hasn't been done...
Once everything is OK...
it will go for many years....
points, rotor, distributor cap and condensor should be replaced at least every few of years depending on how far it goes..
Ignition switches are very old now and are starting to fail..
by placing a relay next to the battery or above the starter motor makes a BIG difference in power to the starter motor solenoid..
Sorry I can't show You any photos as I'm in Adelaide at the moment..
best of Luck
LEE Noonan
baghall wrote:Gidday all
Alright I have had enough. Firstly starter motor problems (starter motor ok), broken clutch cable (fixed), broken arm on clutch operating shaft (fixed), through out bearing ruined cause of saft problem (fixed). All back together, now starter motor not meshing with flywheel (spins when shorted across terminals but engine not turning), not enough power getting to starter when key turned. Is the the life of a VW owner or should I just assume I have been cursed.
Could anyone help me with advice for the last 2 problems.
Thanks!:
crazy:
