Hi all,
I have a n/a 2180 (82x92) I bought as a second hand motor and was wondering what I may have to alter within the engine so as I can run a turbo with decent boost. I will list the parts as I was told, but I can not tell you the compression ratio at this point or even how long the rods are. Do I need to split the case or whats needed. I know that more engine details would help, but this is all I have at this time.
If you know the answer, please add valuable information that will not only help me but many other Vee Dubbers as well.
Engine parts list below that I was given with the engine - in no particular order:
Engle Cam W110
SCAT 1.25:1 Ratio Rockers
GENE BERG Oil pump
CB Performance 82 mm Forged Stroker Crank
Chromoly Pushrods
CB Performance Lifters
Chevy Style Valve Springs
Ported, Polished ccd Pro Street Eliminator Heads
Stainless Valves 42 mm Inlet with 44 mm Outlet (think he got size of these wrong)
92 mm Mahle Pistons and Barrels
Total seal rings
CB Performance H Conrods
External oil filter
Chrome Bosch 009 Dizy
48 mm Webbers (like new) with oiled foam filters, also comes with brand new set of unused polished alloy EMPI Air Cleaners that sit over the stacks
High capacity oil Sump
Straight cut cams
I got a dyno chart with this and it only had about 65kw at the wheels and I thought it would have had more. This engine was in a buggy and possibly bigger wheels may reduce this figure ??
Thanks, Kevin
Camo 路
