About to attempt installing a new sound system into my 69 beetle. Just looking briefly i couldn't really see an easy place to run the speaker wires from the rear of the back seat into the luggage compartment.
As my car doesn't have carpet as yet its pretty easy to run from the rear to the front along the floor until carpet is fitted.
where is the easiest place to run the wires from the front kick panels into the luggage compartment to the dash?
baghall ·
I drilled a hole near the fuel filler which is not noticable when driving and then ran the cables in some corrugated tubing through the hole down the front kick panel and along the side of the floor pan and then up behind the battery to the speaker box behind the back seat. It will be hidden when I fit the carpet. This also allowed me to run cables for a reverse camera and the tacho wires. Also was able to tidy up other cables ran by someone else.
Hope this helps.
barls ·
mine run along with the stock cable run down the passenger side then split off from there. if you really want you can run them down ether side as there is a cable run channel ether side.
Paulc1964au ·
thanks guys I am lucky that the car does not have carpet yet so i will try and run in the cable channels on the passenger side
