WTB Subaru EJ20TT fuel pump control module
https://forums.aussieveedubbers.com/threads/83054/wtb-subaru-ej20tt-fuel-pump-control-module
robertocarlos ·
Hi,
Anyone selling a Subaru EJ20TT fuel pump control module? Cheers
I got mine from Sun Coast spares in Qld.
Lovebuggy ·
Not sure if this will do. I have a spare 2002 STI fuel pump controller. You can have it for $50.
robertocarlos ·
Hey Lovebuggy. Could you please take a photo of the plug that connects to the controller? I just need to see if the wiring agrees with that of the twin turbo. Cheers.
STIDUB ·
got a whole EJ20TT + loom ecu etc collecting dust in my garage, where are you?
robertocarlos ·
STIDUB - oh nice. i live in ipswich throughout the week and head up to my folks place (burpengary) for the weekends to work on the joy known as a purvis eureka 🙂 ha ha ha. ive got the engine and loom all sorted just trying to source a compatible fuel pump control module.
colonel mustard ·
I lol at your closeness to that loom roberto...
robertocarlos ·
well you're right on that one colonel mustard. dad and i (mainly dad) have spent the past 4 weeks trying to sort it out. and i made dad's job a lot harder by trying to retain most of the electrics from the half cut liberty. we've kept the instrument cluster, steering column switches, cooling fans, fuses, relays and other random push button switches. hopefully we'll be able to turn the engine over in 2/3 weeks time so i'll let you know how the wiring really went.
STIDUB ·
sounds like my loom may come in handy? how did you go fitting the TT in with all the plumbing? painful?
wouldnt mind getting rid of the whole lot... if its any use to you, will try to see if its got the module attached when im there next (having a lil bit of a shed clear out)
robertocarlos ·
umm...i think i wont need the loom as i pulled the entirety from a half cut. well the cooling and fuel lines aren't in yet - we are just going use some pre-exisitng components and just test it all out first.
the fuel control module is part of the rear wiring harness plug r122 (i think) - if that helps.
Lovebuggy ·
Here is a picture. it has the loom tail attached, but is cut off at the other end (just beyond the photo).
robertocarlos ·
thanks a lot for that Lovebuggy. hmmm interesting. sorry to be a jerk but how many wires are actually going into that plug. colours vs pin positions would be fantastic if that wouldn't be asking for too much.
why subaru...why!!!
seagull ·
your far better at this point to get rid of the twin turbos & run a single turbo
or
welcome to hell
robertocarlos ·
i'd rather be condemned 🙂
robertocarlos ·
Alright boys, with the aid the photo, I've done some more research. WRX engines use a 6 pin fuel pump control module whereas my GTB uses a 5 pin. I wouldn't even be able to 'trick' the module because two of its wires go to the computer. So...
Lovebuggy - thanks alot for all your help however the unit is not compatible with my ECU.
STIDUB - if you could have a look for the module that would be excellent.
robertocarlos ·
Hi,
Bring this one up again. So does anyone have a fuel pump control module for a 1999 Subaru GT-B? I might consider other 5 pin Subaru fuel pump control modules.
Rob
seagull ·
sigle turbo it Rob
The motor have yellow injectors ?
