Aussieveedubbers 路 Tech Talk
Beetle steel wheel help please
https://forums.aussieveedubbers.com/threads/83228/beetle-steel-wheel-help-please
psimitar 路
Need a hand from someone who has 4 stud 15 inch steel wheels for a beetle. Has to be a Beetle as T3's are different.
Anyhow, i need the ID of the rim where the centre is welded to the rim. This hopefully should be the same measurement as for a wide 5 steel. If so then i can source some 5.5j 4 studs to then weld wide 5 centres into.
So if anyone can tell me this measurement that'd be really helpful 馃檪
psimitar 路
Anyone?
STIDUB 路
so you want diameter where the center is welded to the rim, will look tonight, even better is, i have both 4stud and wide 5 馃榾
psimitar 路
STIDUB wrote:so you want diameter where the center is welded to the rim, will look tonight, even better is, i have both 4stud and wide 5 馃榾
yea that's right. where the centre is welded to the rim. that'd be great dude 馃檪 They're 15 inch too?
