stripping tinware
https://forums.aussieveedubbers.com/threads/83245/stripping-tinware
waltermitty ·
I have a 1600 DP sitting on my bench . Whilst my resto is stalled I wantto strip and restore the tin ware.
It looks like I need to strip the inlet ends and much of the ancillaries to get the tinware off . How far do I need to strip the motor to get it all off? Mitchell
cb john ·
Take off the intake castings, generator and the shroud, crank pulley and that does it..
yep as per above and u may need to pull exhaust from memory
waltermitty ·
Thanks John Dave . Im into it this weekend. Mitchell
Blast and powder coat would be nice or are you just painting ??
beetleboyjeff ·
Give me a holler if you need a hand, I will be around a bit on the weekend.
Give me a ring on 0418 841581
Camo ·
Isn't there also tinware under the cylinders that needs the push rod tubes removed, to remove the tinware.
Kev
waltermitty ·
Dave yeah blast for sure and price up powder coat. Any idea on what thats worth?
I have seen some done black fan shroud and grey for the cylinder / barrel shrouds.
Geff thanks for the offer I am camping at Diamond head over the week end!
Cam yeah there is but It can stay as is this enginew has no oil leaks so i dont wish to upset the sttus quo.
Mitchell
jsheppard64 ·
Camo wrote:Isn't there also tinware under the cylinders that needs the push rod tubes removed, to remove the tinware.
Kev
Ahh yes, that nasty one that I keep forgetting everytimes i pulled it apart.
