Alternator conversion wiring confirmation
https://forums.aussieveedubbers.com/threads/83324/alternator-conversion-wiring-confirmation
GaryFranks ·
Hi Folks, I'm installing an alternator into my 1971 beetle and just want to confirm the wiring before I connect the battery.
The car originally had a generator, and some wag had moved the regulator into the engine bay. I'm intending to move the regulator back under the seat where it belongs.
I have attached a diagram of how I think the wiring should look.
- Will the old regulator be OK with the alternator?
- Do I need to run a new red wire from D+ on the regulator to d+ on the alternator?
- Does the B+ red/white wire go straight to the battery, or should it also connect to the B+ on the regulator?
ian.mezz ·
a lot of alternators have built in regulators
Uber Kafer ·
I have one of those alternators, its Bosch and rated at 50 amps if I can read the nameplate details correctly. The regulator was mounted under the seat but it is a different style, and possibly unique to that alternator. the bosch model number is 0 109 600 015. and vw number is 043 903 803A. It only has 3 wires to it:
Brown D-
Red D+
Green Df
The large red/white wire didnt connect to the reg as it was was jumpered through to the battery and fuse box via a large spade multi-connector at the location of the Regulator.
The Samba website has a bunch of wiring diagrams for beetles listed by model and year, you may get more info there.
alternators use a totally different regulator to a generator so you will have to swap it
have you got a 3 terminal alt like in the diagram?
with those ones you can just get a 2 terminal regulator out of any 70s holden that will do the job if a vw one cant be found
GaryFranks ·
Thanks guys. It's a 3 terminal alternator, so it looks like I need to find a correct regulator.
ian.mezz ·
GaryFranks wrote:Hi Folks, I'm installing an alternator into my 1971 beetle and just want to confirm the wiring before I connect the battery.
Nice diagram...
You need an alternator solid state regulator..
the generator regulator won't work with an alternator...
Sorry I don't have any pics...
Mine has an internal Regulator...
check out:- http://www.vw-resource.com
Rob & Dave's website....
jjwebb123 ·
sorry to hijack.
but what about alternators with inbuilt regulator,how do you
by pass the already installed reg?(underseat)
jjwebb123 wrote:sorry to hijack.
You need to join the 2 thick red wires on the generator regulator, this will join the battery to the alternator + using the thick red wire that bolts to the post on the alternator.
The small blue wire for the idiot light on the generator regulator need to be connected to the idiot light on the alternator, you can use one of the left over wires that connected the generator regulator to the generator.
VW did a smart thing with wiring to the generator so that the wires were not mixed up on the terminal on the passengers side of the generator, bolts on with fully round terminals, the one on the drivers side has a slide in connector.
The fully round connector will be your new + back to the battery, the slip connector can now be your idiot light connection.
PS Gary, you can get a generic voltage reg to suit your alternator.
jjwebb123 ·
bit confusing.
there are only three terminals on my alternator.ground, df and d+,and another one.
idiot light on the alternator?
If anyone has had experiences with inbuilt reg alternators please pm me asap.
jjwebb123 wrote:bit confusing.
Hi Jason,
I've sent You a PM on info on internal regulated alternator....
which only has two terminals...
main B+ to the battery
and the small wire to the alternator charging lamp in the speedo.
this lamp MUST work for the alternator to work.....
pod ·
pod ·
jjwebb123 ·
thanks.
lee didnt get any pm from you mate,not sure what is going on there.
thats wicked pod thanks so much.no chance of getting them a tad bigger ay?
~Jas~
vlad01 ·
Joel wrote:alternators use a totally different regulator to a generator so you will have to swap it
Correct, the 2 regulators work on very different parameters and are not interchangeable.
jjwebb123 ·
do you have to touch the starter at all.
i see some people do.why?
krisko ·
just found this post while trying to fit a beetle alternator in my kombi
purchased a bosch RE57 three pin solid state regulator and the wiring was very straight forward
-thin red from alternator plug to D+ on reg and piggyback to dash light (blue wire on old reg)
-green from alt plug to DF on reg
Brown from alt plug to D- on reg
B+ large feed from alternator straight to Battery
(rip out old wires from regulator to generator and from old reg to battery 😎)
the 2 pin solid state reg mentioned in the above posts is the Bosch RE55 - its the same as the 3 pin but doesn't have the earth as i understand it.
hope this helps somebody along the line somewhere- had me scratching my head for a while
grumble ·
RE57 is the one also used on 2 litre kombi s
