Driving on a lovely 100kph country road with all the brothers in the car... 7 yr old up to 24yr old... we're all there.
Nuffin but sugar cane on both sides... out comes a corner, half way through BANG! WHACK WHACK WHACK WHACK!
WTF!
Rear end flew out, quickly down shifted and drifted it out/corrected and slowed her up and pulled over. Hazard lights on.
half the whole rear left tyre tread had pealed itself off, slapping in the wheel well, smashing up some of the plastic under cover and wearing the brake line to the braiding (didn't break it... thankfully).
The steal braiding of the tyre was all ripped up and it pealed through it.
HOW the hell does it do that? It wasn't a retread. It was old, as it was a spare after a punture 4 weeks ago, (yea we been slack)...
Is this normal?
When tyres get old... what is often the 'failure' process...?
We had no choice but to have a laugh about it, thankfully it wasn't on a busy M1. Made the day more interesting none the less...
mackaymanx ·
Yes, the tread will seperate from the casing of the tyre. Age and underinflation are a big factor in this.
Did you check the tyre pressure on the spare after you fitted it?
bajachris88 ·
We did about 5 days prior cause we noticed the front tyres were looking a little saggy. And that was when we still had the spare on cause we didn't swap back over after getting the punture repaired on the original tyre. (too lazy)
My elder bro's first thought was that i over inflated, I didn't have any specs with me so just went 65psi in front, 60 in rear. My tyres on my other car have a max psi of 200 so figured it should be adequate.
ah well... it was underinflated for a couple days prior to us hitting the servo mind you, so u would be on the money.
65psi FMD 🤪
what kinda car is it?
the only time i've ever had pressures that high was when i had a navara with an excel body on the back which was 750kg on its own and had 500kg of tools in it and they were light duty truck tyres
most family sized cars dont need anything over 40psi
blow outs are a fact of life with tyres that are getting abit of age, thats why they try to encourage people not to drive on tyres that are more than 10 years old cos they start to perish and next thing get hot and blow out like you expierenced
caravans and trailers are shocking for it, cos they never wear tyres out
bajachris88 wrote:Driving on a lovely 100kph country road with all the brothers in the car... 7 yr old up to 24yr old... we're all there.
WTF!
Is this normal?
This DOES NOT Happen usually ....
but an old tyre... running MORE than 30 PSI....
means danger....
You may have contributed to the blowout with the EXTREME PRESSURE.... 60 PSI !!!!!
PLUS it was a very OLD tyre....
if tyres have cracks in them... around the sidewall....
chuck them away....
even though You could get a lot of wear out of them at 30
PSI...
its not worth the trouble.... if they blow... and self destruct
One other thing Chris...
You cannot tell if a tyre has not enough air in them by looking
unless they are really flat... or less then 10 PSI..
and don't run more than 30 PSI....
in a beetle 20 PSI Max front and 30 PSI Max rear...
18 and 28 recommended by VW...
bajachris88 ·
haha, well! there we go :P. I think it was 60 psi... i don't remember. Made it corner better none the less 🙂, the tyres haven't got a dome over the top of em like 'over inflated' kinda look.
Will have to double check ASAP then, but it certainly wouldn't help my cause hey? lol.
colonel mustard ·
68AutoBug wrote:in a beetle 20 PSI Max front and 30 PSI Max rear...
Thats rubbish. 20PSI front? You're dreaming.
NO he's not dreaming.....thats factory specs.
bajachris88 ·
mmm... i like ur boobs craig.
65standard ·
Factory specs for the original pre-cross ply radials of todays tyres. I run the Michelin 165/15 tyres and have been advised by the guys that fit the tyres that the fronts should be 30psi and the rears 32psi due to the structure of the tyres.
My 76 model has the same specs, and that is for radials, remember a beetle only weighs 800 odd Kg and is light in the front compared to 'modern cars'..................I'm not saying its ideal, just confirming that Lee is not "dream'n" !
bajachris88 wrote:haha, well! there we go :P. I think it was 60 psi... i don't remember. Made it corner better none the less 🙂, the tyres haven't got a dome over the top of em like 'over inflated' kinda look.
Steel belted radials don't show their Over pressure same as their under pressure...
Not like the old crossply tyres....
60 PSI and they would be rounded on top...
the steel belting stops that from happening......
PS: the F/R pressures are different because of the weight
differences...
many cars show - increase by 4 psi for fully loaded... etc..
and a Kombi probably more??
bajachris88 ·
ah i see! that explains why i don't see no rounding.
I only eva learnt that from a vw service manual lol, obviously it doesn't apply to late 80's celicas hahaha.
Thanks Lee. 🙂
Hey man, u going to Valla this yr?
11CAB ·
Chris, there should be a tyre placard on the fuel flap or inside the drivers door of your celica to tell you what the tyre pressures should be.
bajachris88 wrote:ah i see! that explains why i don't see no rounding.
Thanks Lee. 🙂
Yes I hope to there Chris
Celica should be around 28 both ends approx... Lee
ancientbugger ·
Chris you had everybody worried there for a while, we thought you'd nearly damaged a VW🙂
bajachris88 ·
lmao!! 😂
and it ain't my car either lol.
Thanx 11cab, i will have to take a peak. on my ol' bomb (toyota) its in the glove box, it wasn't in my bros (the one that blew up) so it must be in the fuel cap then.
if not will google. i will check the tyre pressures tomorrow when the brother's at work and will reduce them, so he doesn't send me the bill by piecing together my contributions to the failure lol. It was an old tyre anyways...
h ·
glad to read everyone is ok
bet you had the brown undies happening
bajachris88 ·
Thanks h,
yea it shook us all up.
But all we could do was laugh (once we pulled over). These 'side of the road' catastrophic failure situations are kinda getting old now, this stuff keeps happening to me!
13bwagon ·
the only thing rubbish is the crap you talk!
go on say it you don't care about anything i say
Yogie ·
The problem with the factory recommended pressures is that they do it for comfortable ride and not tyre wear. We run 32PSI all round on ours and they handle fine with nice steering weight and a comfortable ride as well.
Yogie
barls ·
i found 28 in the fronts and 30 in the back otherwise it bounced too much in corners.
bajachris88 ·
I know this thread is old news now, but who eva is interested, i got a photo of the tyre:
hate to say it but that looks like a remould (not a retread)
anyone who's running more than 20-21psi in the front of a bug clearly knows nothing about tyre pressures, weight distribution etc of a rear engined car
doesnt matter whether they're 14" pizza cutters or 18" fanbelts pressure is pressure and they need it around that value for correct steering/handling characteristics
About the only exception is offroading tyres but they're not gonna handle nice no matter what you put in them
bajachris88 ·
ah! intersting. whats a remould? oldskool method?
h ·
cold or hot cap
orig case new lid ontop
truck tyre speciality
Joel wrote:anyone who's running more than 20-21psi in the front of a bug clearly knows nothing about tyre pressures, weight distribution etc of a rear engined car
Couldn't agree more.
Right on again Joel 👍
HappyDaze ·
Can't see how anyone can justify driving around on crap tyres! I suppose it's down to how much you value the well-being of the occupants.
On the subject of pressures, all you need to do is read the manual. For what it's worth, I run 19F, 22R in my '59 race car - on the track.
Cheers, Greg
Yeah Greg, imagine the grip with 30F, maybe there's something we've been missing!
bajachris88 ·
Any tyre that holds air and has tread does the job for me as a spare 🙂. i mean... its a spare...
Cars over 2 decades old tend to loose the manual...
I've learnt my lesson though.
They kinda don't teach ya these things in driving school, nor does the rwc inspector look at the spare tyre. go figure...
Uber Kafer ·
Having done several advanced driver training courses, one course in passenger cars the other course for 4wd's, I can vouch for the importance of getting tyre pressures right, and once you learn the basics you can confidently manage your tyres without referring to glovebox manuals or tyre pressure placards.
Just doing the 'swerve, brake & stop' test with different tyre pressures will blow people away about how important tyre pressures are.
2 important rules:
Never buy tyres on price alone,
and never trust tyre pressure guages at service stations ( buy a good one and look after it).
71-BEETLE-SEDAN ·
One qeustion what brand was this tyre, my brother bought a charade and its rear tyre was split about where thr tread would meet the frame of the tyre. Then when i bought my rims this week a same brand tyre had the same problem in the same spot.
HappyDaze ·
That's pretty good advice there by Uber Kafer (above), Josh. Just remember - you have 4 fairly small patches of rubber between you and oblivion, try to make them as good as possible!
Cheers, Greg
71-BEETLE-SEDAN ·
I know greg, the day i found the split in my brother tyre made him go get a new one on it and made sure he didnt get the same brand or the el cheapo one. Also made sure he got a good spare tyre.
Im going to get new tyres on my rims anyway as the were all bald and im gunna try get potenzas as they seem to be really good.
