Hi folks, just finishing up changing the engine in my bug. Anyone know which connection on the fuel pump goes to the tank / carby?
I gather this is a circa 1974 engine, with the leant-over pump that allows the alternator to fit.
Thanks!
Gary
with the tin top ones the inlet from the tank is the top and the bottom is outlet up to the tank
if you remove the screws on the top theres actually a filter underneath
the old bolt together style like the other have the connections the other way around, outlet on the top
if u look closely at the tubes there is usually a directional arrow for flow
