CHEAP ENGINE PARTS
https://forums.aussieveedubbers.com/threads/83381/cheap-engine-parts
vwsteve ·
Ok going through the crap in the shed and sorting out what i dont want
steve 0409475131
caboolture qld 4510
I am not a holding yard so if you want something pick it up asap, im not holding it for ages like in the past.
Type 3 side draft carby1 and a 1/2 $50
1 type 3 singleport carb and manifold $25 ono
3 1200 distributors $50 lot
vwsteve ·
Twin port heads condition unknown $50 pair
steering boxes, condition unknown $25 each
vwsteve ·
kombi engine crossmember $20
i have rods, pistons,cranks, pushrods,rockers,and all sorts of crap for 1300-1600, make an offer
i have 4 stud rear drums and brakes off swing and irs, $50 pair complete ono
i have front 4 stud discs $25 pair
Pumba ·
Steve are the inlet ports on a single port type3 bigger than a beetle single port??? cheers shane.
vwsteve ·
no idea shane but i doubt it, i would assume they are the same
Pumba ·
Now im confused,i got a set of twin type 3 carbys with home made manifolds and linkages of a beetle, but the inlets on the manifolds are bigger than my beetle heads, so im guessing the beetle they come of has a type 3 motor in it🤪
vwsteve ·
who knows, maybe they were made bigger?
vwsteve ·
box full of vw fuel pumps, must be 10-15, conditions unknown $50 box
type 3 vacuum advance distributor gc $25
bajachris88 ·
any working alternator/fan assemblies.. (rather than generator)?
Probably bit too heavy/exy to post to goldcoast way though hey...
vwsteve ·
no alternaters chris
grumble ·
vwmad if you have home made manifolds and they are a different size they may be to fit 1200 heads.
grumble ·
vwmad if you have home made manifolds and they are a different size they may be ??? are you running a 1600 motor/
Pumba ·
Its all good,problem solved.
SKEWtYpe3 ·
vwmad wrote:home made manifolds
i think thats your answer
jedidan ·
vwsteve wrote:Autobox and starter pending
I should be out this afternoon / evening to pick them up. I will text you. cheers - daniel
Pumba ·
That wasnt the answer??? because my standard manifold wouldnt fit the heads that the home made ones come off ???
vwsteve ·
autobox and starter sold, no oval steering boxes left, a few 60,s and 70,s ones available
tayloredvw ·
hey mate do you have any super bug parts? im looking for a left door and left front guard, and windscreen.
vwsteve ·
i had a guard a while back i couldnt get rid of and threw it out mate, i have a windscreen for you, no door.
pm sent
