Aussieveedubbers · Rods and Rats Forum
Air Bag suspension Legal?
https://forums.aussieveedubbers.com/threads/83397/air-bag-suspension-legal
rothko78 ·
Tried to search this but couldn't find anything....
Is air bag suspension legal or able to be engineered for street use in NSW?
Brad
Aspro ·
Not sure about NSW but here in VIC you can have it fitted as long as there is a limit switch fitted which prevents you from adjusting the height while the car is in gear. Very easy to overide when it is fitted.
I've also heard that the car must always be above the 100mm required by law so that if the bags fail it still rides at a safe height.
barls ·
give the nsw rta tech line a ring
MR930 ·
Yes its legal with a engineers report. There is a mob at Forster doing the conversions. They also organise the report. I'll see if I can get his details.
rothko78 ·
Thanks for the responses!
I am actually looking at a beetle that already has air nag suspension just wanted to make sure i can get it rego'd in NSW as it is currently rego'd in QLD.
Pumba ·
You talking about the one on ebay ???
rothko78 ·
no not the one one ebay...bit over my budget that one.
this is the one i am looking at:
http://www.melburgluft.com/viewtopic.php?t=7413
Pumba ·
No worrys, it is a little pricey the one on ebay,You have to be a member to see the one on luft ??? cheers shane.
barls ·
be aware that they may not accept the engineers report from qld.
grumble ·
May is not the key word if the engineer is not on the RtA certification list it
the report will not be accepted
utter buggery ·
I can't see the one on Luft? i tried registerinng and it wouldn't even let me do that.. something about wrong answer?
oztype3 ·
air bags suspension in QLD, can have air bags as long as its Digital dakota system ( autolever) and all switches cant be operated whilst driving.
then you ll get a mod plate and engo Cert.
but other than that get it Regoed in NSW its all legal as long as its modplated
oztype3 wrote:but other than that get it Regoed in NSW its all legal as long as its modplated
As Grumble said - as long as it was originally certified by a NSW RTA Engineer
A Qld mod plate means jack when you take it to a NSW blue slip person
Otherwise it will be a new eng cert berfore you will be able to get a blue slip
It is not something you can hide
