I have just finished assembling another engine this week . This is a 2110 cc engine that will suit any type 1 , 2 or 3 and is 100% brand new with the exception of the rocker arms . Here is a list of all components ;
AS 41 magnesium universal case bored for 94mm
Empi cro-moly 76mm forged counterweighted 8 dowelled crank
AA cro-moly 5.4" I beam conrods in chevy jnl
KS std main bearings
Clevite 77 conrod bearings
Mahle dual thrust cam bearings
Scat C 25 camshaft with Scat gear
AA 94mm piston/barrel kit
Ported 043 heads with 40mm & 35.5mm stainless valves
Scat 8mm cro-moly head stud kit
Case install kit
Crank install kit
Dizzy drive/shims and spring
Brosol 26mm oil pump
Empi oil pump cover
Case nut and bolt kit
Oil pressure switch
AA 36mm cro-moly gland nut
AA 12 volt lightened cro-moly flywheel
Scat solid rocker kit
Scat swivel feet adjusters
Scat .035 cro-moly pushrods
Steel cam plug
Scat bearing dowells
Gasket kit
Rear main seal
AA flywheel shims
Zinc push rod tubes
Scat solid lifters
Scat stainless steel rocker cover kit
Cylinder deflector tin
Steel sump plate
VW oil strainer
Scat .177 cylinder shims
This engine has a compression ratio of 8.5:1 and should produce around 90 hp . It is located in Wollongong NSW 2526 and can be freighted any where in Australia for free this month for a total price of $ 5040 delivered , ROD , 02-42729920 .
RodPenrose ·
