WTB: L bug steering column shaft
https://forums.aussieveedubbers.com/threads/83472/wtb-l-bug-steering-column-shaft
beetleboyjeff ·
I am after an L bug steering column shaft - from the upper universal joint to the steering wheel. I need the one with the smaller splines on the top for the wheel (about 17mm - not the 21mm one).
Buyer: Jeff Walsh
Ph. 0418 841581
Email: beetleboyjeff@hotmail.com
Postcode 2444 - Port Macquarie (but I am working in Newcastle at the moment, if that is any help).
vwsteve ·
if they are the same as superbug i have a complete column inc wheel for $50, steve 0409475131
Superbug (1302) will be the thicker one
Jeff
What exactly are you after
I have a shaft - but not all the bearing and stuff that is at the top
May even have a new universal as well
Barry
beetleboyjeff ·
Barry,
I only need the shaft itself. Everything else is OK except the universal, but I have one of those - the splines between the shaft and the universal are worn - the clamp has come loose at some stage and allowed it to wear. I have tightened it a few times, but it still has movement, and is getting worse.
How much do you want for it? I am very interested.
DylanTheDubber ·
Jeff , Im thinking of splitting the money with a few people to bring back a 75 superbug with full rack and pinion an all the late super stuff. It's $250 so the more people that put in the more likely we get the stuf we want real cheap.
From Dylan
beetleboyjeff ·
Dylan, I will try and give you a ring tomorrow afternoon.
You coming down to the Nationals??
How about a 6 pack of Stellas??
beetleboyjeff ·
I am hoping to, but I will have to see what happens with work. I am working in Newcastle now, but still trying to finish jobs in Port Macquarie. I hope to know more after the weekend before the Nats.
donn ·
PM sent Jeff
OK - I have it dug out sitting here
Whatever....... 👍
beetleboyjeff ·
Barry, I might see if I can come down and pick it up after work on Monday or Tuesday evening next week if that is OK.
DylanTheDubber ·
Jeff , My phone has been out of action. Try tomoro afternoon , it will be all good then.
From Dylan
beetleboyjeff ·
OK Dylan
funbug ·
DylanTheDubber wrote:Jeff , Im thinking of splitting the money with a few people to bring back a 75 superbug with full rack and pinion an all the late super stuff. It's $250 so the more people that put in the more likely we get the stuf we want real cheap.
From Dylan
Dylan, I am looking for the ignition lock on this bug - it houses the ignition switch. The part number is 113905851A.
