Does anyone know where i can get someone to make some moulds so i can repro these seals?
Any suggestions would be great.
which ones ???
XXX-1.8T ·
They are off my albert mirrors but you cant buy the seals
Will Vintage ·
Clark rubber is your friend dude
greedy53 ·
the rubber under the mirror i use tap washers and there are a few coluurs
XXX-1.8T ·
so does clark sell something like this:
pod ·
you would have to find a rubber parts manufacturer ,then they will give you a tooling cost ,which can run in the thousands of dollars
cam070 ·
pod wrote:you would have to find a rubber parts manufacturer ,then they will give you a tooling cost ,which can run in the thousands of dollars
Yep tooling up to produce seals like that will cost you a fortune. If you get a real price, make sure you are sitting down, or better still lying on the floor when they tell you.
squizy ·
What about using a thin strip of rubber and just running it around to shape?
the tool to produce those will cost you more than its worth to buy 50 sets of new mirrors
snowman9 ·
You could try:
Peter Jackson's Old Auto Rubber Co
4/4 Appin Place Dunheved (St Marys) NSW 2760
Phone (02) 9623 5333
greedy53 ·
you all mite think i'm past it and well ovwr the top ,but i needed a gasket for an very old part that i wanted to use on my v rod,so i filled a straw with clear silacon worked a treat just a thought
annosL ·
'O' ring kits are similar, lengths of varying thickness neoprene, you cut to lenth and join by super-glue
modulus ·
greedy53 wrote:...,so i filled a straw with clear silacon ...
That's a great idea. You could even make a "straw" out of paper in different shapes e.g. triangular or rectangular.
hth
XXX-1.8T ·
greedy53 wrote:you all mite think i'm past it and well ovwr the top ,but i needed a gasket for an very old part that i wanted to use on my v rod,so i filled a straw with clear silacon worked a treat just a thought
