WTD: Dellorto Aux Venturis
https://forums.aussieveedubbers.com/threads/83619/wtd-dellorto-aux-venturis
Vanders ·
I'm after a pair (for one carbie) of auxillary venturis for a 40mm Dellorto DRLA carbie.
Used, but good condition is fine. The pair I have have been slightly melted due to a stuck butterfly.
Any help appreciated.
Paul
Sorry can't help with the parts, but are you sure the cause was a stuck butterfly, that should only make the engine rev, I've had a Kadron burnt in a customers car years ago, and the cause was a very burnt inlet valve. I'd be checking the valves for sure.
Vanders ·
They were like it when I bought them so I'm not sure of the cause. May not have been from the stuck butterfly. They are going on a new (rebuilt) motor so I shouldn't have any probs.
Dasdubber ·
I'm pretty sure I have quite a few venturies out of 40 dells - will check tomorrow at work and will get back to you.
Al
Vanders ·
That would be fantastic Dasdubber.
Dasdubber ·
I have a set of four 26 and a set of four 34 venturies.....let me know if either will suit.
Al
Vanders ·
Are these mains or auxillaries? I'm set for the mains, its just the auxillaries I need.
Paul
