For Sale.
1 x CB performance alloy T1 case
Has the standard CB case features:
6 x shuffel pins
Clearance for 86x94
oil galleries all drilled and tapped for plugs
etc... See : http://www.cbperformance.com/catalog.asp?ProductID=1230
Ive also had the case machined for a flanged crank. You can use an adapter FW seal if you want ot use a standard crank in the engine though too.
Other modifications are:
Oil pump return gallery tapped for a block off plug
10mm case saver inserts
I had the rear oil relief valve welded/modified so I could use it as an oil supply input, but this has now been drilled out again so it will work as a normal case.
I have a german oil pickup here somewhere too, and throw that in with the case.
Im after $500 for the case, plus freight.
The case has never been run before. I have only mock assembled my 2443 in the case but ended up going with an oxy boxer case instead.
The case is located in Cairns and i'll freight it anywhere in Australia at the buyers expense. Estimate a max of $50 to melbourne. I can be contacted on 0434 147 478, PM'd via the forum or emailed at ian@isit.net.au. More pics available on request.
Ian.
2443TT ·
