O ring and seals question
https://forums.aussieveedubbers.com/threads/83683/o-ring-and-seals-question
57 oval ·
Just bought a gasket overhaul kit for a 1600 T/P and although I know that they supply gaskets and seals for most engine sizes in the kit, what is the about 50mm O ring for ? also there are six thick O rings about 13mm dia.
there is a seal / oring type about 25mm and while I am in asking mode two black rubbers about 10mm high about 10 mm outside with about an 8mm bore and four browny colour 12mm outside dia 8 mm bore and about 8 mm high.
I have fitted a new set of barrels and pistons and new heads to my twin port but havent seen these items any were in my travels, also about to do the rear main seal, do 1600 T/P have a oring in the inside bore of the flywheel? any help appreciated
RJ
the 50mm goes in the flywheel
the 13mm are for the 6 crancase center bolts
57 oval ·
Found were this one goes
"seal / oring type about 25mm "
on the distributor shaft were it fits into tthe block
Found were the 50 mm goes thanks
six o rings not needed as I didnt split the case
Thanks for the reply thou
Just got to find a home for these
"two black rubbers about 10mm high about 10 mm outside with about an 8mm bore and four browny colour 12mm outside dia 8 mm bore and about 8 mm high".
All of these looik like a small piece of tube
RJ
pod ·
sounds like the oil cooler seals
yep cooler seals
57 oval ·
Nop not them, the set had two different types of oil cooler seals, used them, still the mistery seals
grumble ·
Browny colour or white (depending on supplier of engine set)may be the rocker shaft seals for the 40hp
some sets supply both types of seals
so depeneding on which engine you have
depends on which seals are used
