71-BEETLE-SEDAN wrote:What do i do if only two of he six studs are still in the case or not snapped off.
I can get three nuts on. two nuts and one thread comes out with a nut. Now its not holding oil and leaks too much, what do i do?
YIKES
You do have a problem...
You will have to get the broken off studs out some how..
if the threads are damaged...
You can buy stepped studs...
with a thicker thread in the engine and the normal size thru the plate...
buy a few spare studs they are cheap...
and also get a new set of nuts... also cheap..
You also need to get a small spanner to use on those nuts..
long spanners will only cause problems...
they don't have to be that tight...
and always use an oil change kit when changing the oil...
and a small amount of gasket cement on the gaskets...
making sure the sump and plate are oil free...
PS: just changing My oil now... Castrol GTX2
