Aussieveedubbers 路 Buying, Selling & Swapping Parts
fs nsw ej22, ej20t block, ej25 dohc na
https://forums.aussieveedubbers.com/threads/83695/fs-nsw-ej22-ej20t-block-ej25-dohc-na
Klaus 路
okay sick of tripping over it in the shed so the ej22 (1993) has to go , comes with computer and half the orig exhaust all wiring and parts that make it run inc subi starter but not the conversion kit .
seller klaus pohl
dapto nsw 2530
$$$250.00
pm , phone , sms , email, telepathy if you can
0428 427 986
eleven75@bigpond.com
pics if needed its a motor 馃檪
will now chuck in 97 wrx ej20t block n heads (still together) and a ej25na dohc with manifold $350 for the lot . wrx block has reco heads but a conrod problem and the ej25 has reco heads but blown gaskets (previous owner cooked it)
psimitar 路
Is it an EJ221 or 222?
colonel mustard 路
That's damn cheap!
Klaus 路
whats the diff , its a single cam coil pack out of a front wheel drive liberty sedan
Joel 路
itd be a EJ22M or possibly one of the first EJ22E
psimitar 路
221 is earlier engine so 135bhp lower torque at higher revs and 222 is 143bhp but more torque at lower revs so means it's a nicer engine.
Engine number should tell you 馃檪
Joel 路
Dont go by what wiki says, its so far off its not funny
it doesnt go into the aus models but theres 3 models of EJ22 used in AUDM libs
90-94 gen 1 EJ22M 100kw/ 189Nm @6000rpm
95-96 gen 2 EJ22E 94kw/ 190Nm @ 4400rpm
97-98 gen 2 singleport exhaust EJ22? 98kw /193 @ 4400rpm
PS sorry for the hijack klaus
Klaus 路
all good just means its a 1st gen...... now someone get it out of my shed 馃檪
psimitar 路
Ah, sorry Klaus really wanted a Gen 2 馃檨
Joel, looks like we do get a mix here as seen both 222 and 221 plus the E n M's. Ah well 馃檪
71-BEETLE-SEDAN 路
hey klaus, im keen but i have no money, i may be keen in 5-6 weeks if you still got it.
Klaus 路
a deposit makes me keep it馃檪
Pumba 路
71-BEETLE-SEDAN wrote:hey klaus, im keen but i have no money, i may be keen in 5-6 weeks if you still got it.
Plan on saving up your lunch money馃槀
71-BEETLE-SEDAN 路
yep, and my drinking money and my gamblig money
68-bug 路
I'll say he's probably getting very little lunch money?, because he said he'll buy a motor of me, and I never heard of him again!, maybe he was grounded !.馃槀
colonel mustard 路
i think maybe a few people have heard that from... people.
sometimes money is tight and you just have to do what you can... which sometimes means not taking on a conversion that can cost easily 5times the engine cost (or alot more in this case)
Pumba 路
What it means is that if you dont have the money to buy what the seller is selling.dont tell them you are going to buy it???
colonel mustard 路
Agreed.
Klaus 路
if there is an issue I'll keep it and delete the add.
Too many panties in a bunch around the vw world at the moment馃槀
colonel mustard 路
no issues, just saying, dont hold it for people, take the money and get your self some free space. sorry to be interruptin! 馃檪
71-BEETLE-SEDAN 路
pics?
Klaus 路
its just a ej22
71-BEETLE-SEDAN 路
still for sale?
Klaus 路
yep
Klaus 路
bump
General_Failure 路
If it had the adapter stuff I'd move heaven and earth to get it. 馃檨
Klaus 路
i can sell you the adapter and 228 flywheel for an extra 600
philsmanx 路
will you just sell adaptor and flywheel? sure it will fit an ej25 ill check if your keen...phil
Klaus 路
yeah pretty sure it will fit ,got it from volksconversions ring him to check , postage might be near $50 not light
DylanTheDubber 路
P.M Sent
psimitar 路
Don't post. Check out www.e-go.com.au
Cheap, efficient courier service that beats Couriers please etc hands down 馃檪
ezyboy 路
hi,
my engine is blown in my kombi, im new to the kombi family and was wondering would this engine be ok???
are they all the components i need for the conversion???
psimitar 路
Well he's got the engine and ecu plus adapter plate but you still gotta sort a radiator and piping up to the front of ya bus 馃檪
Klaus 路
you would need to make a crossmember , sort out fuel system or get a efi kombi tank (i do have a bay tank with a commodore v6 pump fitted inside it) i also have a hq v8 rad pretty good cond might even be brand new, stock clutch might hold up to a ej22 , not sure if you would need to flip throttle body/ manifold .
vss ie speed sensor but i modded the speed sensor out of the subi front cut in my wagon to fit inside the stock guage housing.
This is a cheap engine which woulb be great for a conversion or parts.
bargain on up to 5 grand for a type 4 rebuild getting a shop to do it.
MR930 路
Are you able to courier this ?
Klaus 路
anythings possible with $$ but at the moment i'd be struggling with time to get that sorted for a few weeks , you might be able to find someone passing this way to move it for you.
Joel 路
2 pages of replies and noones bought this yet?....WTF? 馃お
geez an engine with loom and ecu wouldnt leave u much change for under 1k from a wreckers
If i wasnt so far away it would be in my shed now
psimitar 路
Joel wrote:2 pages of replies and noones bought this yet?....WTF? 馃お
if it was a gen 2 it'd be in my shed mate 馃檪
Klaus 路
for an extra 100 bucks I'll chuck in a 97wrx block with heads and a ej25 na dohc motor ej25 has blown headgaskets but also had reco heads in the past and ej20t has conrod problems . thought both had blown headgaskets but only 25 also they have been sitting outside .
Joel 路
Oh now you're just teasing
philsmanx 路
psimitar wrote:Well he's got the engine and ecu plus adapter plate but you still gotta sort a radiator and piping up to the front of ya bus 馃檪
front back under it all seems to work if youre able its cheap.... long thread馃槀 aye
