T1 Fan Housing Throttle Cable Tube
https://forums.aussieveedubbers.com/threads/83777/t1-fan-housing-throttle-cable-tube
BeetleJuice ·
Does anyone know where I can get a NEW T1 Fan Housing Throttle Cable Tube?
I know I can get one from CSP in Germany. I believe theirs are made in Germany.
I want quality!
Craig
do u want 36 40 or late style as they vary
u will prob only get S/H ad a clamp to the rear to lock it in place as well makes fittings cable n stuff easier
Camo ·
You can always try these out. I have bought one, but not fitted yet.
http://www.thesamba.com/vw/classifieds/detail.php?id=731107
http://www.thesamba.com/vw/classifieds/detail.php?id=786740
Kevin
Camo wrote:You can always try these out. I have bought one, but not fitted yet.
Kevin
WOW Kev...
You should have bought a box of 'em...
One of the best improvements I've seen that should be on every engine.... IMHO..
PS: vw54.. Yes, Mine is a pain... I'll have to put a clamp on the end... good idea..
I always weld a tag on the stock tube and put a self taper in it, same idea.
You can see it in this photo of my sons motor.
i used to do the same thing
but its alot of work when a few correctly sized washers, a piece of fuel hose and a clamp do the job just as well with no fabbing needed
The good thing about having it secured is that if you break a cable you can feed it all the way though without getting under car as long as you have the sheaf over the transmission in place.
Just getting back to the original question, just find a tube that fits in the "over the transmission sheaf" snugly and the weld tag on like Joel and I did.
bushed ·
sheath = plastic tube
sheaf is a wheat cob of seeds lol
i have few oldies 36hp had a sqre stp plate sim to samba's one
Actually a bowden tube or sleeve, I believe.
EXCELLENT WORK GUYS...
SOMETHING I WILL HAVE TO DO..
BEFORE MY CABLE CUTS THRU THE TINWARE AT THE BACK..
BeetleJuice ·
Thanks Guys
I ended up getting one from CSP with some other bits.
CP
What car is this for Craig ??🙄
BeetleJuice ·
Craig Torrens wrote:What car is this for Craig ??🙄
It's red and gone from the lounge room into the garage.😂 And thanks for taking the piss!!!!!!!!😂
Dak-A-Tak ·
Use a speedo cable outer tube and a zip tie at back , leave it long ,say half way across gearbox .
