Aussieveedubbers 路 Tech Talk
*URGENT* Float Level *URGENT*
https://forums.aussieveedubbers.com/threads/83805/urgent-float-level-urgent
Smiley 路
Does anyone know what the float level should be set to on a 31 PICT-3 on a 1600 SP engine?
Or know where I can find the info?
Quick replies would be very much appreciated as I need to get it sorted ASAP.
Smiley 馃槑
Bizarre 路
have a read here
http://www.vw-resource.com/float_needle.html
68AutoBug 路
Smiley wrote:Does anyone know what the float level should be set to on a 31 PICT-3 on a 1600 SP engine?
Smiley 馃槑
i DON'T THINK ITS A GREAT ISSUE..
place a washer under the needle and seat to lower the level
its usually a leaking needle and seat that causes the problem.
something that You should keep as a spare...
as they do wear out..
if it floods with one washer, add another washer under the needle and seat to lower the float level again..
PS: If You have renewed the fuel pump recently, thats usually the cause... too much pressure on the needle and seat.. Lee
Smiley 路
I have revised the issue.
I did what Lee has suggested above. The fuel level was to high in the bowl.
Going to take it for a run and see if it fixes the problem. Was running like a dog before.
Smiley 馃槑
68AutoBug 路
Yes,
too much fuel is nearly as bad as not enough...lol
when the bowl fills up it just overflows into the carby throat..
I hope it fixes the problem...
Smiley 路
It helped to fix the problem.
The fuel level was wrong there's no doubt about that.
But the main problem was burnt points and incorrect timing.
I also screwed the idle screw in a bit and the mixture screw too.
Seems to be running a million times better.
I'll give it a proper run tomorrow with a short trip down to Brisbane 馃槀
Smiley 馃槑
OZ Towdster 路
Just down the track i tell ya ................. well mabey 600 odd k's down the track , but who's counting when your driving an empty tin can
68AutoBug 路
Smiley wrote:It helped to fix the problem.
Smiley 馃槑
I ran My beetle VERY rich for a while...
goes Much better when its correct air/fuel ratio..
didn't go as good as it does now...
and used heaps of petrol...lol
funny as some points don't last..
may be the coil or condensor..
some cars just chew them up.. [burn them up]
even with new coil and condensor....
Smiley 路
Smiley 馃槑
Mine burnt the points cause I had the ignition on a fair bit while I was wiring everything up and checking that it worked. If you have the ignition on and the car not running you will burn points cause there is current constantly running through the system.
Smiley 馃槑
