Bay Bits
https://forums.aussieveedubbers.com/threads/83826/bay-bits
flipflopsurfer ·
I have a few bits to get rid of, they're just taking up space.
I have some bay glass pieces that I no longer need. I think there is the rh rear, both centre pieces and front fixed 1/4 lights, came out of a 69/70. Anyone wants them free,come and get em.
A type 4 engine front cooling ducting thing, the whole aluminium front flat cooling bit (technical, I know) with type 4 cooling fan and alternator, not sure if it works, no play in the bearing, spins freely, again free to anyone.
A stock front beam from wide5 lowlight, spring packs and bump stops, no rust at all, I would rate a very good condition. Comes without centre relay and damper. $150
Wide 5 lowlight stock spindles. Could be used for dropped spindles or porsche conversion, these are the last year of spindles that you can easily adapt porsche hubs to fit. Kits are reaily available and CSP do their wide 5 discs or 5 x 130 kits to fit these. $100
Have some engine parts.
Mesa 72 plate external oil cooler with fan. It measure 205mm x 280mm or 8 x 11 inches. Fan works perfectly and no dings in the plates, seen less than a couple of 1000km's. $80
Mocal oil thermostat, opens at 175 deg to flow oil to the cooler. It's the OT/1 model
http://www.thinkauto.com/oilstats.htm. $40
Free type1 porsche fan shroud, may be good to take a mould, been cut badly around the inlet manifolds. (not by me)
Have 2.5 x in/out full flow pumps, similar to CB's maxi3 pump.
http://www.cbperformance.com/catalog.asp?ProductID=195.
Good for stock or near to stock engines, provides the provision of oil filter without having to worry about clearing exhausts. 3 x oil pumps, 2 x covers, 1 cover has been modified to remove right angles in the flow path, one is untouched, havee the 3rd cover , but it was cracked at the outlet fitting, by a monkey swinging on a spanner. ( not me either) $100 for everything.
Bugpack fully merged 1 5/8ths exhaust header. This is the version that allows for the use of heat exchanger, unlike normal merged exhausts where you have to go without heating. All slip joints are secured with pinch bolts.
http://www.coolairvw.co.uk/Item/Shop_by_Manufacturer~Bugpack~Exhausts/AC251200920/Bugpack_Streetmax_42mm_Merged_Header_With_Tabs_For_Tinware.html
Not ceramic coated $200
I'll get pics as I drag them from the back of the garage.
All the parts are in Little Mountain, Caloundra, 4551.
0405 627 972
Jon
