I have all those sharp, hard to budge nail things that were in the pan to hold the original body to pan seal in place.
I have tried to use a hammer to jig em out but it started to dent/bend the metal surrounding it.
Is there any tips or special hints to doing it?
or just... perhaps a pinch bar and deal with it....
Chris.
grab with a set of side cutters from under neath and twist out
bajachris88 ·
thanks for that 👍 i will give that a whirl!
Camo ·
As Dave said, but make sure you spin the right way as they have a twist on the shaft. I know you mentioned the hammer and I assume you mean a claw hammer to try and remove. I also used a punch and hit them from the other side. Hit the point of the nail.
Kev
HappyDaze ·
If you haven't already removed them, grab the heads tight with vise-grips and twist anti-clockwise while pulling out firmly.
Just done all of mine (poor old No8 '59 Beetle) - only broke 3, and they knocked out OK with a sharp punch.
Cheers, Greg
bajachris88 ·
thanks heaps guys,
that worked a treat! 👍
Pulled them out with no worries at all, and just punched out any ones that broke.
Nasty sharp looking things
I presume yr replacing the seal ( eventually )
If so use a little contact glue to hold the seal in place while fitting the body
bajachris88 ·
yea the body has been off the pan, prepping for holidays coming up where the body is going back. (how many times in the past have i planned for that moment? lol)
no worries. yea will use heaps of windscreen sealer 👍, i'm going to need 2 body to pan seals as well, cause i got the 2'' lift kit. it will be interesting... 'to say the least'. I'm a bit nervous in the whole process. But will be rewarding if i see it through.
Camo ·
I have a feeling that you are not meant to use windscreen sealer, but let others be the judge of this.
Kev
71-BEETLE-SEDAN ·
sikaflex is the stuff i believe
I suppose windscreen sealer would be OK, you need to use something that has no acid in it.
I reckon a pair of pincers would get the tacks out OK.
no worries, Thanks guys. i will just use the body to pan seal and sikaflex. I like sikaflex too.
i got the 'spikes' off doom out of the chassis :P was no trub at all! 🙂 hopefuly get this pan and body mated again soon.
will check out that dab off :P
