Make metal tarnish or rust?
https://forums.aussieveedubbers.com/threads/83969/make-metal-tarnish-or-rust
XXX-1.8T ·
I have this metal badge not sure of what its made out of but i cant get it to rust or tarnish.
I have tried white vinigar and balsamic vinigar with no luck.
Any other ideas?
battery acid?
colonel mustard ·
brake fluid... ?? it strips paint.... and should corrode coatings...
bus914 ·
If its metal, sea spray will do the trick.
greedy53 ·
you can get aging meterial from any craft shop it can make cement look like brass aged
Gringo_54_oval ·
Hey costa at a paint store called murabond in artarmon they sell a paint that imitates rust in an orange or charcoalish tone ask for geoff 9906 7299
might be what your after.
shaven ·
wee, tomato bush
bajachris88 ·
easy done... i can show u a photo of the results if u like...
pool store, $10.50 for 5 ltrs of hydrochloric acid. Mix 50/50 with water safetly,
leave in there, take out, and leave it in the atmostphere outside for a couple days.
Only works for steel i have noticed. if its aluminium or alloy, then it won't work.
shaihulud ·
A very old trick to make new metal objects look very old is to bury them in a pit in the ground and to piss in the pit for months.
It's used in Asia and the Middle East to make new brass and bronze statuettes look like they are centuries or millenia old, so that they can fool unsuspecting tourists into believing that they are geniuine antiques.
