I have a 1916, 110 engle, twin kads, Bandido heads, extractors on a quiet pack.
Used to go like a shot. Good torque, easy to cruise, nice car.
I re kitted the Kads recently. Just before a dyno day. I was shocked to find that I had halved my horsepower!!!
The dude on the dyno reckoned I had major issues inside the engine and suggested I replace the cam which he reckoned MAY have been the issue. (As in lobe worn down)
So I drove it home. Went like a black dog. No power. It has 155psi compression in all cylinder. The cam lift has been measured in the car and it appears to be ok. So I am not pulling it down just yet.
Got into the carbs this morning and the accelerator pump delivery tube has a small ball under it. One was not seized but there was a lot of crud and stuff which was keeping the ball jammed up off the seat. Which means (correct me if I am wrong) the pump metering is now askew??
Anyway is this sufficient to cause me major power loss on one side of the engine. (from the two dyno days I did with the same engine and carbs I lost almost exactly half engine power).
All suggestions appreciated.
regards
Old Hutcho
Did it feel like it had lost power??
Old Hutcho ·
Yes. Big time
regards
Old Hutcho
greedy53 ·
unkitted good kitted bad a bit of a clue there i think
a big pull apart and a good clean and a b low through all jets AND ALL GALLERIES IN THE CARBY BODY this is nearly always forgotten
Old Hutcho ·
Greedy
Point taken. However, I did pull the carbs right down, solid flush with degreaser/carb cleaner, light blow through and back together again. All jets and galleries flowing freely. Including the accellerator tube. The question really is. If the ball under the accelerator tube doesnt seat properly, what effect does that have. I am hearing accelerator pump not delivering correct quantities of fuel as some fuel drains back down into the pump? Is that pie in the sky stuff?
regards
Old Hutcho
Is it farting and popping
My thoughts if it was fuel it would be making all sorts of noises
I am a bit confused as in how it is behaving??
Is it down on power or is about to die???
like - is it driveable?? just with 1/2 the power??
71-BEETLE-SEDAN ·
and check plugs too
Old Hutcho ·
Bizarre
Its not farting or popping. Its just down on power. Big time
Old Hutcho
throw the Kadrons away total waste of time
So wot made u swap ???
pod ·
how is the balance between the 2 carbs
Old Hutcho ·
VW54
Ive had the Kads for a long time now. I have had no probs with them so far. I am not even sure they are my problem now. Just clutching at straws.
pod.
The balance is fine. Tubes all new and clear.
Old Hutcho
Could it be a blocked muffler? I had a glass packed muffler block up once and it really cut down the power.
Old Hutcho ·
SteveNow THERES something I hadnt looked at. I had a custom one made by a local mujffler shop. Never thought to stick my head in there.
Will do so tomorrow.
Old Hutcho
LOWBUG ·
Yep get rid of the tin cans and put some decent carbs on it, disturbing them has stuffed them, in reality there not great carbs to start with, your lucky they lasted this long.(but what do I know). Any advice on the forum is risky.
Thinker ·
when you rekitted the carbs was that including new jets, where they the same size and dont mean where they stamped the same.
also when the carbs went back on how where they tuned, by ear by smell or by gas meter.
gas meter tells alot about whats going with the mixture
I no the Kads can work well BUT they do play up and require someone who knows linkages and carbies to tune them
Hows yr ignition system do u have 009 or similar
try an electronic module ( not the cheap chinese one either ) and get the ignition right so it dosent vary
Also get a length of plastic tube one end in yr ear and the other to check for suction vacuum leaks round the mainifolds they tend to come undo cause there top heavy and vibrate with the engine movement
