1776 Turbo motor +Oval body with goldie roof section
https://forums.aussieveedubbers.com/threads/84008/1776-turbo-motor-oval-body-with-goldie-roof-section
Split Bug ·
Name - Anthony
Number - 0411 041 555
Sydney Chatswood
It is a rebuilt 1776 engine, new everything except for case, which is a mint thin stud AD case, standard cam, German lifters, Male piston and barrels, VW 040 heads. comp is 6.9 to 1. it has all the tinware, exhaust with muffler, Weber DMTT blow-through turbo carb, Modified distributor for retard under boost. IHI RHB5 turbo, pod air filter, Saab Intercooler, blow off valve, Bosch fuel pump, Malpassi boost sensative fuel regulator. everything is there to bolt this into your car. all the hard work has been done, There is over 30 hours work in the pipe work alone!!
The engine has been run in only and not been driven on the street since being built. It is built to last and is an ideal street package, Quiet, economical (28 to 30mpg highway) and quick,.
To fit this to a Beetle a couple of holes need to be cut into the bottom of the parcel tray for the turbo and the intercooled, and a 2nd fuel line needs to be run back to the fuel tank for the fuel return.
$3500
Split Bug ·
Pic
is that dave beckers old setup?
Split Bug ·
Yes - was made for a mate of dave's.
Split Bug ·
Oval body with split graft , some small section of rust , 2 holes in rear firewall – grafted goldie roof with sunroof & new head liner & goldie skin $2000 ono
NuZo ·
any idea on power output mate?
Calcool ·
I am interested in the rag top and roof clip if someone wants a cheap good Oval Body I am willing to divide up the costs.
The body buyer can just graft a roof panel from another Beetle in.
I have seen this body and it would not take a lot of work to put into mint condition. Anyone want a split, oval dashed drag car? Well this is a good option and cheap if we go in together, say 50 50!
David
0434 58 22 64
Your generator is fitted 90 degrees out, the earth screw should be at the top, free bump.
Split Bug ·
Body Sold
Euro_67 ·
Joel wrote:is that dave beckers old setup?
Looks like the turbo fitted to My car by the original owner "Shimo", long before I got it.
Last time I saw the bits Matara was going to do something with them. Where did you source the turbo bits from ?
