headliner
https://forums.aussieveedubbers.com/threads/84010/headliner
robb ·
anyone got any solutions on how to get or make lighter the brown staining that appears on head liners mine is very light but still s ts me
65busser ·
I reckon there's not much you can do about it robb. It's usually the glue overspray on the inside of the liner from when it was fitted. Goes darker the older it gets. Can be rust from the bows that's seeped into the liner if the car's spent years out in the weather. In both cases the liner is stained so have never heard of a remedy.
If it's yellowed from cigarette smoke you've got a chance. I've got a cleaner that'll help that. pm me if you want some.
Brad
robb ·
hi brad thanks for the the info i put a new head liner in myself early nineties but from memory left in the old padding you made me think may be that is the pobl there was no rust that i could see i do remeber pulling it back to see but in saying all that i did have a few fags in it on those long drivies gota try something dont fancy going down that road again whats the name of ya stuff ill try and get it in sydney
thanks again
robb
65busser ·
Robb. If you speak to Dan at Double D Auto he carries some of our products in Sydney. http://www.doubledauto.com.au/vinyl-cleaner/
Brad
robb ·
thanks mate will let ya know
vlad01 ·
If all else fails try vht vinyl dye and respray it. that stuff works wonders. I used it in my crumpledore (commodore) to change a few interior plastic parts to a completely different color. looks like factor now and does not come off unless I grind it off.
robb ·
man what a mess that would leave would rather leave as is not to mention the fumes i agree good for small jobs have used before thanks anyhow
I have used the vinyl spray
It was when i had all the windows out so it was well ventilated
If your window rubbers are in good nick and you can pop your windows easily it is a great option if the only problem is the discolouring
yep i would vinyl spray it or replace with a new one there reasonably cheap
65busser ·
Only possible issue with spraying the headliner is if you've got a perforated liner it blocks most of the holes and if you've got "black dot" headliner where what looks like perforations is actually black dots printed on the vinyl, you loose the dots.
That VHT vinyl spray is the goods though isn't it?
robb ·
hey brad picked up ol school from dan have tried a little seems to have made it lighter [eyes are not what they used to be] will give it a few more goes in the same spot see what happens dont want to popping windows again thanks again
