Aussieveedubbers 路 Non-VW Engine Conversions
Clutch
https://forums.aussieveedubbers.com/threads/84063/clutch
MR930 路
OK, I'm putting an EJ22 into my Kombi. I'm using a 200mm clutch. Do I use a standard Beetle Clutch or do I get a better quality one ? I plan on towing a trailer a lot.
ian.mezz 路
i think Josh and I just have a stock Sachs clutch plate and a kennedy stage two pressure plate (ej20t bugs, young josh broke his gear box uno doing burnouts馃檯 etc but the clutch still looks new馃お馃お
Joel 路
You might get away with a stock disc but theres no way a stock pressure plate will last in kombi especially one towing a trailer
i had a brand new stock sachs clutch on my 1776 and it was fine till i started adding boost.
Only took 6psi to start making it slip and thats only in a 840kg bug
There was a kennedy stage1 famine on so I ended up replacing it with a Exedy sportstuff stage1 HD which is now on my EJ22 and its happily taken the abuse I;ve thrown at it
