wiper motor wiring
https://forums.aussieveedubbers.com/threads/84162/wiper-motor-wiring
clinker42 ·
Hi Guys
The 2 speed wiper motors, can you tell me how it is wired, is it just an earth, then one power for low speed and another power for high speed.
Thanks Trev
waveman1500 ·
There are different types of 12V wiper motors, the ones which are designed for a dash switch and the ones for use with a column switch. The two types are wired differently. Basically the difference is in the way the park function works, the dash switch ones earth through the switch when they park and the column switch ones don't. Both have 5 wires I believe, one is earthed to the body and four to the switch. For the column switch, one is live power with ignition, one for low speed, one for high speed, and one which somehow makes the park function work by some method I don't fully understand.
clinker42 wrote:Hi Guys
Thanks Trev
Hi Trev,
NO
but You could wire it that way...
then the blades won't be self parking...
for beetles with switch on the dash 1968>
the self parking feature actually goes thru a switch in the wiper motor itself.. and earths out the motor to stop it..
You need to look at wiring diagram before You wire it up...
and don't hook it up with the wiper assembly in Your hands as it doesn't stop when You turn it off... lol
it self parks on Your fingers.... YIKES...
One lesson I'll never forget....
Need to know what model year Your beetle is...
or Your wiper assembly is... lol
as mentioned... there are a few different assemblies..
You May be able to fit the 1968 beetle two speed wiper
motor assembly to Your earlier beetle..
as the shafts are the same size... small
but the hole spacing may be different...
plus whether its RH or LH wipers... lol
Non Super beetles from 1968> had LH wipers...
made for LHD cars...
I have the wiper info here... I'll post it tomorrow night... Lee
clinker42 ·
Done it thanks guys
The colum switch one powers the motor for park function as well.
ancientbugger ·
Lee, I'm so pleased I'm not the only idiot who's done that😁
ancientbugger wrote:Lee, I'm so pleased I'm not the only idiot who's done that😁
it hurt more than having Your finger cut off.... lol
and it was jammed in tight...
IMPORTANT INFO:
NEVER OPERATE THE WIPER ASSEMBLY IN YOUR HANDS...
lol😂😂😂
