The brakes on the 69 should be sufficent ..
if You get MORE braking on the front , the front wheel will lock up and You don't stop...
Most of the braking is done with the front brakes...
unless some kind of bias is done to brake more on the rear..
its no problem to adjust the rear brakes...
and make sure You have no more than 20PSI in the front if You don't want to skid.. or lock the front wheels all the time..
and Very good tyres on the front...
You just need to learn NOT to brake too hard as the front will lock up very easily if hit hard...
on any surface...
PS: many people fit type 3 rear brakes on beetles as they are wider than the beetles, but still need adjusting... Lee
My Son bought new front brakes years ago for his beetle and the brake pads are much larger than normal beetles..
maybe type 3??
PPS: Put YOUR Location down... make a lot of difference...
Aussie Dubbin wrote:Sorry if its been Covered???
I am looking at upgrading brakes so i can get great response from my standard weight 69 Bug, I want to make sure i eleminate that light feeling you get from the front end, and heavy rear feeling... eg the front lock up but you don't really stop???
I have done some reading about 944 conversions and also putting standard calipers on the rear with a little bit of work?
What am i getting out of 944 setups? can i just do the rears??? Can i just put a 944 disc on the rear and then mount standard type 1 calipers on the rear and then an additional handbrake fitting??? Or even 944 rear standard front??? Bais valve (porportioning valve)
What will i get? Am i over working the system, should i just put type 3 rear drums on and go from there???
