More Heater Rubbish
https://forums.aussieveedubbers.com/threads/84204/more-heater-rubbish
clinker42 ·
Hey Guys
Nearly finished but ran into another problem, the fresh air box up front has two hoses going into it from the two side air vents, problem is, if you look at this picture they dont line up anywhere near close enough. Yes I do have the side ones in correctly and that centre one also can only go in correctly.
Anyone have any ideas.
ian.mezz ·
i JUst looked at my vw and the fittings are the same size .
you must have parts off of two different models ???
ian.mezz ·
oh yeah make sure you have a plastic cover over the radio as water does get in.
all that is correct parts for the 71 onwards style flow through ventilation.
You're just missing the corrigated reducer hoses that join them up.
I may even have some still in my crap pile
71-BEETLE-SEDAN ·
On mine the pieces that join those pieces have different izes on each end, and they are also offset. Looks like thats what you need
clinker42 ·
Thanks Guys
Joel, would be fantastic if you could find some, I have spoke to a couple of wreckers down this way and they said they throw em when they strip.
ian.mezz ·
is it a superbug,
try autobarn they have tubes and stuff that are fully sick.
clinker42 ·
hahaha
Fully sick, Im not sure my daughters beetle could hand fully sick stuff on it lol
No dramas will see what I can find.
Ian theyre a custom made for the job hose
you wont find anything at supercheap to do the job
ian.mezz wrote:i JUst looked at my vw and the fittings are the same size .
Yes,
the ones on My beetle which are not actually connected to the fresh air box at the moment...
are the same size and about 50mm away from each other..
just a small piece of the paper covered foil hose [as used in beetles] joins them together.. maybe 75mm long..
only thing, it may be an odd size...??
but I have ones from a 68 and 71 and I was sure they were the same sizes....
