Phone: 0410 420 577
All prices negotiable, and plus postage.
Pick up OK
Prefer to contact via reply post or PM please
UPDATED 15/6 WITH ITEMS PENDING AND SOLD
EDIT: Realised I have the manifolds for the IDF's and added roller pedal assy & j-tubes.
I'm selling a few bits I've been hoarding for a while but can't see myself using in the near future, need to raise some cash to get my squareback interior through customs, forgot about that!!
1. Stock 85.5 pistons and cylinders, new in box $200 (pending)
2. Engle TCS10 turbo cam, new in box with lube $120
3. Bugpack HD single valve springs, new $35 (Sold)
4. Pair of 36IDF's with manifolds that have been lightly ported, probably just match porting (before I got them). I bought them on here a few years ago, was told they were jetted for a 1600, I've never run them. No linkage or filters. Carbs and manifolds only $330 (Sold)
5. Bosch Type 1 alternator, was bought new a few years ago and only used for about 3 months, good cond, still has 40Hp fan attached to it $120 (Sold)
6. Berg type rubber mounted mid mount $100
7. Type 3 dash for a 72-73, has been recovered in beige, I assume it is vinyl paint over black $150
8. Oval roller pedal assy, painted a wonderful shade of red by a PO, $100 (Pending)
9. Kadron j-tubes, new $40 for the pair (Pending)
I have a couple of stock carbs and distributors lying around in the shed off various early beetles, let me know if you want some details on them.
I thought I had some photos of this stuff but can't find them anywhere, will try and get some on here over the weekend.
type3lover ·
PM sent re turbo cam
05bjp90 ·
and re. type 3 dash 😉
HGFS ·
Pics of P&C's and cam:
HGFS ·
Pics of valve springs and IDF's / manifolds:
HGFS ·
Pics of alternator, mid mount, j-tubes:
HGFS ·
Pics of type 3 dash and roller pedals:
HGFS ·
type3lover wrote:PM sent re turbo cam
05bjp90 wrote:and re. type 3 dash 😉
Both replied
71-BEETLE-SEDAN ·
Whats the exterior diamter of the cylinders where they enter the case?
And for what size motor is the j tubes/
Chop Top VW ·
Hi Greg,
do the pedal assy, fit a 68 beetle
thanks
HGFS ·
With nothing better than a standard tape measure at hand, the cylinders are around 89-90mm at the case end. Standard 1600 engine size.
The j-tubes are 1 3/8" diameter, they should be OK for anything from a 1600 to 1916 or so.
ciarog9 ·
PM SENT
HGFS ·
Chop Top VW wrote:Hi Greg,
thanks
I don't think so, later pedals mount to the floor but the oval pedals are mounted to the tunnel without fixings under the accelerator pedal.
Greg
66brm ·
Do you have the longer studs for the mid mount?
HGFS ·
No I don't, all I have is what is pictured, this is how it came when I bought it from another member on here.
I guess a fastener place like coventry etc would be able to supply the longer studs?
gavandrob ·
Hi do you know how much the pistons cost to post to vic 3842 thanks gav
HGFS ·
Hi Gav,
Looks like about $22 postage mainly due to weight.
Greg
Turbo54 ·
I like the red pedals - what were they thinking?
BUMP
T54
LUFTMEISTER ·
Hi will take p&c . p.m sent for payment details
HGFS ·
LUFTMEISTER wrote:Hi will take p&c . p.m sent for payment details
Cheers, replied
Have updated first post with pending & sold items
HGFS ·
Turbo54 wrote:I like the red pedals - what were they thinking?
BUMP
T54
Yeah if you like the red so much you can take the steering column cover back for your own piece of redness!! I'm sure it will look awesome on your oval
