Anyone know if this is just a direct bolt in replacement or not?
Keen for the safety upgrade of a collapsible column as well as a steering lock and accessories key position.
newghia ·
If by LATE you are talking about the one that is flat on the upper side of the plastic shroud,
and early being curved / round in the same place, then i believe it can be as that is how mine is in my 65 T34 ghia.
Nath
hellbugged ·
no not direct, but possible.........i'll get some photos of ours
from your recent posts sounds like a pretty major rebuild your up to?
type3lover ·
Thanks guys. Daimo it would be handy to know what's involved with it.
Yeah still fiddling about with the blue notch! Engine rebuild #4. Trying to get it up to a roadworthy state. Still lots to do!
ernie norley ·
Gday all Just a suggestion I have fitted a TF gemini colunm into my 72 baja theres a bit of fiddiling with the wiring but all I did was weld beetle bracket onto it. It fits straight up to rubber is the correct length this set up gives you washer wiper headlamp hi/lo beam from memory the TG colunm is different just a late model alternative for little work
Ernie
type3lover ·
Interesting Ernie...I hadn't thought of a different brand. In this case I think I will stay with what I have until a good late type 3 column comes up.
