engineer certificate
https://forums.aussieveedubbers.com/threads/84257/engineer-certificate
IN THE WEEDS ·
hi everyone i am in need of an engineer on the central coast to get an engineer certificate for my beetle does anyone know of one and a contact number for them would be good
cheers chris
There is a bloke up there called Lakeside??
I know several people that have used him
Have a look on the RTA web site
VDU.88A ·
HUMPHREY Kevin
Lakesedge Engineering
Services Pty Ltd
4 Willow Tree Road
NORTH WYONG
NSW 2259
P: (02) 4353 0866
F: (02) 4353 0877
M: 0409 454
Also have a looks at this links its got them all for NSW.
591http://www.rta.nsw.gov.au/registration/downloads/vsi/vsi_15_engineering_signatories_rev_20_23march_2010.pdf
Is the vehicle registered or going to be because there is a few new changes coming near the end of the year regarding engineer certificates etc Engineering signitories and the whole process. Essentially engineers certificates will become void after a certain date and a new method called VSCCS (Vehicle Safety and Compliance Certification Scheme) will come into effect where once it is signed off by the engineer the rta will be notified and then you will have 21 days (i think) to present the car for a blue slip and adjustment of records done.
So if you have a engineers certificate currently but havent notified the rta of it or had an adjustment of records done i suggest you do because after a certain date they will no longer be recognised.
vlad01 ·
question?
if you do a whole lot of modification, welding, fabrication etc.. and do it all your self. you just take it to an engineer for a check over and certificate?
or does everything need to be done by a engineer including welding?
barls ·
i suggest talking to the engineer before starting mods as there may be things they want you to do when doing it.
then you can just go back and get them to sign off on it
vlad01 ·
Yeah I was told by people I know that every thing need to be welded and designed by engineer. I didn't believe it as I see nearly all moded cars were done by the owners.
So is it true you can DIY? thats the main thing I just want to clarify.
barls ·
that depends on your standard of welding doesn’t it.
vlad01 ·
yeah of course.
You can do DIY on your car if you can do DIY properly. If welds are left as finished without being sealed over or ground back, then the engineer can easily see the quality of the weld, making sure there is penetration without excessive undercutting.
vlad01 ·
awesome thanks. just wanted to know. there is plenty of time to learn for me. I have my car, I have my plans now I just need to get some work so i have the money lol.
see I have 2 jobs sort of lined up but can't work them til me and my two employers figure out a system were they can afford me and still make it viable for them and not to hard for me due to my illness.
haha just a dream atm. ahh EFI turbo notch 😵
