Adjusting Camber
https://forums.aussieveedubbers.com/threads/84259/adjusting-camber
sander288 ·
Is it possible to adjust the camber on a link-pin front end?
how do you go about doing it if it is possible
Well,
on a link pin front end...
I don't know that one...
I only know about ball joint front end beetles...
I'm sure someone will be able to help You..
grumble ·
The camber is adjusted with the shims on the link pins,there is a set number of shims and these are fitted according to the offset of the torsion arms.If the front end has been set up correctly the camber should be right.Let me know if you need more info regarding the set up.
From memory it is also covered in the Idiot book.
