Narrowing the rear end of an early Bay IRS kombi
https://forums.aussieveedubbers.com/threads/84275/narrowing-the-rear-end-of-an-early-bay-irs-kombi
vassy66T1 ·
HI
The question is whether this is possible, has anyone done it, and what does it involve?
I have some new 15" Fuchs wheels to fit to the SC and do not want to go for a tyre size that ends up increasing my revs at a said speed. I had some 205/70/15 fitted for the rears and they don't make it under the rear guards. The front look great with 205/65/15 though.
With the 205/65 my speedo is only 0.4 mph out at 60mph
The 205/70 rears will drop my revs by approx 80rpm at 100kmh.
Any help is appreciated.
Marcus
waltermitty ·
narrower tyres / different offset wheels both options . Narrowing rear NO optoion. Mitchell
modulus ·
Since you have a single-cab, you don't have the normal problem with Kombis of the sliding door clearaing the guards, so you could get the guards nudged out a bit; it's one of the (many) advantages of single and double cabs.
hth
TICK ·
i narrowed the rear of my ute . big job . 245,60,15
vassy66T1 ·
Thanks for the reply Luke.
Have you (or can you) put up the work/process involved in doing this?
I don't need to go quite as far as you have (am only looking for around 30mm inwards) but am somewhat keen.
There ya go Marcus....you'll have to trade in a pair of those wheels for some 7's ....or are they 8's??? just to make it worth while 🙂 Looks awesome Luke.
vassy66T1 ·
Agreed ... very cool look ... that could be worth some late night/early mornings 😁
dangerous ·
Aaron has narrowed his, fick him a pm.
Don't think Marcus will go that far, air bags etc etc....oh....and 700+hp :-D
vassy66T1 ·
I am opting for the custom wheel manufacture instead.
Test fitment in a couple of weeks with 8"s on the rear all being well 😁
greedy53 ·
try using ford or toyota as they will go on but this is just to see what fit best in offsets
than you can order what ya want
vassy66T1 ·
A guy in Brisbane called Race Engineering still does rim modification.
Late bay steel centres with 15*8 drop steel rims at around $230 per rim.
That is with me supplying the original wheel and he supplies the band, fits it and then I get to paint/powdercoat it.
